2521 - 2540 of 2640 Posts
ILM Ray,
Do you know of any plans for another channel on 26 to take the place of ThisTV?
Yes, I am not at liberty to discuss, but WSFX will be adding a new channel. It should happen soon. It will not happen until after the Superbowl which is on Fox this year.
Ray
  • Like
Reactions: jspENC
I always liked the “Superfox” name. IIRC back then Myrtle and Lumberton used WECT as an NBC affiliate. Florence got WIS/Columbia. Before WMBF came into existence.
I called WSFX and the lady I spoke to said its the new channel will be Court TV. She said she's pretty sure anyway. We already have that on channel 6.5 in Wilmington. So if she is right, we'll have another duplicate channel. That what you got sir?
Ray
6-5 is Court TV Mystery, formerly known as Escape, which is a separate network from Court TV. (Same ownership though.)
- Trip
Anyone around Wilmington able to still get WTMV ? Cozi, Antenna, Movies! etc. We lost the main channel from Kinston a couple of days ago (WTMH). They shut down the transmitter. The Jacksonville channel 41 has been out for months.
Any chance WTMV changed the channel they were broadcasting on? The main channels in the Wilmington area are changing Tuesday at 1 am.
I'm too far from WTMV to have ever gotten a signal from them, but I wish i could get it.
regards
Discussion Starter #2,528
regards
Hello all,
The thread originator is back and OTA is on my mind.
After exploring YoutubeTV for 30 days it is not going to work for me. I loathe the layout and lack of DVR options, I have been with directv ( technically still am) for 20 years ...at least for a few more days. Due to storm concerns, I removed the OTA antenna that was suspended 10 ft above the 22ft roofline. I just worried about it too much, and that was the end of OTA over 5-6 years ago. In the last 30 days I picked up a Lifetime tivo ota/cable box for a very very good price and have it all active on my account.
6
Equipment:
I have the following equipment available to use:
Mohu Leaf (amplified via usb adapter)
Mohu smaller leaf jr i think (came with a tivo box from seller)
Zenith Silver Sensor mini yagi style antenna
Tivo OTA Roamio box: 4 CH ota tuner
Tivo Cable Box: I am planning to run 6 cable tuners as well
Location: Right near ashley hs / going towards CB, I can hear the marching bands in the evening during football season.
I have the Mohu Leaf taped in the back window on the outter wall of the living room. I am not getting more than 50-62 signa strength with peaking at 72. But it gets a lot of drops. So it hovers between 52-55 usually.
I dont get PBS at all i realize its a different direction completely
I get 3-1,3-2,3-3 etc the best of them all. 6-1 and subs are kind of spotty, Fox is better but also a little spotty.
Generally can i select a better option for indoor for now for an omni-directional. The MOHU does not seem to be doing that great.
Silver Sensor better option maybe ( mini yagi).
After pulling down the double bowtie a few years ago I tossed the rotator as it was pretty weathered and rusted out. Just didnt need it laying around.
I will not be using my directv dish much longer. Any decent options for attaching an antenna on the dish or the mast with a ubolt or something maybe. My neighbor has a pole mount right on the front right side of his house, but my other neighbor has a very large tree right where I would put an antenna to tap into the coax system in the house on my right side.
Any ideas or feedback welcomed. I would like to run 1 OTA tuner box if anything for a backup with cable goes out. I still have to put in my order for cable / cable card with Spectrum. Never a fun trip to the spectrum store I am sure. Its always crowded from what people say.
Any other TIVO OTA users out here still?
My first OTA digital experience was with a MYHD tuner card and an HTPC, my most recent was with the DirecTV AM21 tuner addons. My current experience is with Tivo OTA 4 Tuner Box
Why not just get a good directional UHF antenna and put it near the ground outside? I can get the Wilmington channels from Jacksonville at 10 - 15 ft above ground, so you should be able to. When a hurricane is coming, I bring my setup down. Of course it is getting to be every year now, but I enjoy antenna tv too much to not put it back up near 30 ft.
I can get the Wilmington PBS 39 (real 21) at 65- 70% now, since they raised power and changed channels. Also WTMH is off which was also broadcasting on 21.
My experience with an indoor antenna is that moving it even an inch can cause a big difference. In one spot it picks up WILM but not WILT, an inch or two to the right it picks up WILT but not WILM. The only thing I found that worked was to set up a TV set that had signal-level displays where I could see it while moving the antenna around. I'd set the TV for one difficult channel, and see which spots worked for that channel. Then I'd switch to another difficult channel, and see which spots worked for that one. When I found a couple of spots that worked for both, I checked the signal levels on the big stations to pick one.
I just had an outdoor antenna put in, and even with it pointed straight at the Delco tower (WUNJ showing a 93-98 level!), I don't get a detectable signal from WILM. But my indoor antenna gets a solid signal from WILM, because I positioned it specifically for WILM. I do, however, get an almost usable signal from WILT, which is pretty much 90 degrees off the side. So whenever I can get a long enough ladder, I'm going to reaim the outdoor antenna to try to get a good signal off of WILT without compromising WUNJ too badly.
The optimum antenna location makes no sense to me. It's not something that I could puzzle out ahead of time. Experimentation is absolutely necessary.
A final note on experimentation: be prepared to do it again if needed. When I was placing my indoor antenna the first time, I was getting weird results -- including multiple Charleston TV stations. Apparently there was some ducting going on. And when we put in the outdoor antenna, I was getting WTMV, but now I'm not (I'm in the Sunset Park area, over by the ports).
The Mohu Leaf is omnidirectional. The antenna doesn't care which way the signal comes in. However, as noted above, antenna location makes a huge difference.
If the mounting pole is usable, sure. I imagine that most any outdoor antenna will go right on there. I had Dish TV install my outdoor antenna, and they use the Televes Dinova (aka Diginova) BOSS amplified antenna. They installed the same support pole they'd use for the dish, but put the Televes on there instead.
I just had an outdoor antenna put in, and even with it pointed straight at the Delco tower (WUNJ showing a 93-98 level!), I don't get a detectable signal. Experimentation is absolutely necessary.
For indoor or outdoor antennas, I have found the Antop 800SBS model to be a strong, reliable performer. It has an indoor stand, LTE filter, and built in preamp with adjustable gain and dual outputs. And detachable VHF dipoles. Also the various Clearstream antennas from Antennas Direct are strong performers in a compact size, and can be used indoors or outside, and you can add a preamp to increase performance. The Clearstream 4MAX is bidirectional, while the Clearstream 4V has a reflector screen. And there is a new version of the 2MAX sold at Walmart, but you have to order the indoor stand separately. But these are my general observations not specific to your location. In some cases a stronger High VHF antenna may be needed.
If you are not picking up WTMV, I can confirm it is on the air. Channel 35 real. 29x's virtual. I am watching it. Also picking up Azteca HD on WQDH 18 real. dot 2 and 3 have commercials. Dot 4 has color bars.
Can anyone confirm that WWAY, WECT, and WSFX moved overnight as scheduled?
- Trip
Yes, and they come in a little stronger too, mainly WECT. It is nearly maxed out on two TV's and is maxed out on an Insignia.
My signal levels at 68 miles away seem to be about the same as before, but I do agree... WECT is now a little bit stronger than WWAY for me as well.
mans147
Our signals being the same or better is interesting, since I just read reports of people around the tower saying they can't hardly get a picture, or they get nothing. I think they are getting overload if anything on a cheap amplified antenna, or are amplifying an outdoor setup that doesn't need it.
WECT and WWAY normally have a medium, but solid signal for me. WSFX signal is hit or miss, especially during the day. So far, all is relatively unchanged for me. I am very pleased that I am still able to receive the Wilmington stations about the same as before. I was very worried that I might lose them after the switch. I realize that 68 miles is quite a stretch.
If you have a TIVO the guide is all jacked up after your rescan for WSFX, WECT, and WWAY
Also WTMV and WPXU have the wrong frequencies listed
Reported this to them so hopefully they get it cleaned up sooner than later
Well it appears we are going to have yet another duplicate channel here in Wilmington. WSFX has a screenshot up saying CourtTV Mystery will be on the air on January 16. That will take the spot vacated by This TV. I get 40 channels at my house. Sounds like a lot right? But almost half are duplicates, then we have 3 shopping channels, 2 cartoon channels for the kids, a Spanish channel and 2 infomercial channels. Arent there other choices than getting a station that's already in Wilmington? How about the Comet channel? That's on WCTI out of New Bern.
Speaking of WCTI, where have them channels gone? A couple months ago I could pull them in. Especially at night, but not anymore. Did they move to another tower?
