It took them 3 days but see my email conversation with WinDVD support below. In addition I would like to add that I have had a great experience playing SD .vob's from my HTPC. The color has been very good out of the box and video motion smooth without any jitter. I comparison tested it with TMT 3, PowerDVD 9 and ffdshow on some DVDs I have had the most compatibility problems with. Here's the email...
Subject
WinDVD 9 Plus Blu ray bitstream
Discussion Thread
Response (Robby) - 07/28/2009 02:34 PM
Dear Mr Zei,
Thank you very much for your e-mail.
WinDVD directly supports Dolby Digital, Dolby Digital Plus, Dolby TruHD, DTS, or DTS-HD so audio signals are directly sent to the audio device "as is" or in your term, bitstreamed.
I'd also like to note that PCM is also directly supported in WinDVD 9.
Please do not hesitate to contact us for any further questions.
Kind regards,
Robby
Corel Customer Support
Customer (John Zei) - 07/25/2009 08:12 AM
Can you please tell me if WinDVD 9 Plus Blu ray will bitstream a Dolby TrueHD and DTS Master Audio signal or if it is only capable of processing those formats and passing them as PCM?
John
Subject
Discussion Thread
Dear Mr Zei,
Kind regards,
Robby
John
