Status
Not open for further replies.
1 - 3 of 3 Posts
Ok, under the setup video options on WinDVD Platinum, it has options for Hardware Decoding Acceleration and Hardware Color Acceleration (or something to that point). Which one should I have enabled? I'm assuming that DXVA is Hardware Accelerated Decoding, but just wanted to make sure. What exactly does the Accelerated Color option do? Also, others have posted that they can get WinDVD Plat to play back .ts (or .tp) files, while when I try, it only plays the audio, just black screen with video. Everything works fine with my MyHD card and my pc handles Hi-Def .ts files just fine using VLC and Dvico FusionHD software demo. Any ideas why WinDVD Plat won't play them? Any help would be appreciated.
Dell 4500 P4 2.4Gz
512 MB Ram
AIW 9700 Pro
80GB HDD
40GB HDD
MyHD card
Dell 19in Flat-Screen CRT Monitor
Discussion Starter · #2 ·
bump
Discussion Starter · #3 ·
Anyone? I don't know much about the ATI cards since I've always had nvidias, so any help would be appreciated on getting the most out of this card.
1 - 3 of 3 Posts
Status
