Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
I've taken the plunge and now have an HTPC running.
Problem is I get no audio whatsoever from WinDVD. I do get audio for everything else, just not DVD. I know that that Intervideo doesn't support the M-Audio card, but others on the board have recommended the combination, so it must be possible.
If anybody has any ideas I would appreciate it. I've hit every group and forum I can find, and have come up empty.
Here's what I've got.
Abit KG7-RAID
M-Audio AP 2496
ATI Radeon 8500DV
W2K Server
TIA,
AW
· Registered
I think you've run into the mute bug. Just click on WinDVD's mute button and you should hear something. The mute on-screen-display will appear while you hear the sound.
Have you tried WinDVD 4? I haven't upgraded to see if the problem was fixed.
Actually, I finally gave up on InterVideo and switched to TheatreTek.
1 - 2 of 2 Posts
Status
