Status
Not open for further replies.
1 - 2 of 2 Posts
Is anyone else experiencing problems with WinDVD Platinum? I'm getting spontaneous reboots which seem to be caused by right clicking while the DVD is playing. After the reboot, I must reinstall my sound driver because I get NO SOUND as it seems to fry my driver. I've never had a bit of trouble with WinDVD 4.
My system:
Dual PIII 733mhz
1gb RAM
Radeon 7200
Delta 410 using analog outs
Windows XP
Kevin.
Discussion Starter · #2 ·
I've been doing more testing and here's what's happening.
I do a fresh install of the Delta WDM drivers and everything is fine. MP3s play, I get multi-channel analog out from WinDVD 4 and ZP. When I run WinDVD Platinum and start playing a movie, it remaps my channels 1/2 to 5/6. I verified this by running Avia and using the surround sound channel loop. If I shutdown WinDVD Platinum and run WinDVD 4 or ZP the remappings stay in place and I get no left/right channel sound. MP3s don't play because they are trying to play to 1/2 and the remapping isn't supported with the player (MP9). Is anyone else having anything like this?
Kevin.
1 - 2 of 2 Posts
Status
