I'm trying to model the same driver and will be using NX6000D as well. Here are some of my thought/observation on learning the model software and from reading through other forum posts (there are so many posts to read).
I don't think the rated 3000W
@4ohm is considered realistic; the actual output may be somewhere around 60% of the rating, or ~2000W
@4ohm, which coincidentally lines up with the UM18's rating for 2000W peak.
The back of my NX6000D lists 120V ~ 60hz and 620W. In my experience, that data would indicate that the amp will only pull maximum ~5 amps from the outlet. (Some forum threads have people installing dedicated 20amp circuits for the amp, which I do not understand yet.) The difference between 620W input and 6000W output would presumably be met by capacitors in the amp that could help meet peak demand. If only 620W max can come into the amp, then 620W would be the RMS output as well (probably reduced further by efficiency losses).
In my winISD model, I seem to be hitting cone excursion Xmax at around 1000W input signal for lower tunes, 11-15 hz. A sealed box appears to allow 1400W input signal before hitting Xmax. My winISD models are showing more 10hz SPL output for a box tune at 12hz with 1000W input versus a sealed box with 1400W input.
winISD lets you add a high pass filter in the 'Filters' section. I'm trying 4th and 2nd order BW @ 14-17 hz, to try and mimic the recommendations in the MartySub thread. This filter prevents the excursion from blowing up at low frequencies.
