Winter thaw: SI HT-18 "for-fun" build while I wait for a UXL. Used HST-18 instead.
I am new to the DIY subwoofer concept, so I really want to build a sub myself. I have spent the last few weeks just reading up, so now ready to start a thread. Although I have funds to buy $1-$2k sub, I am really just doing this for the fun of it - I like to find new hobbies and this seems right up my alley.
I placed an order for an HT-18D2 a few days ago, and am on the waiting list for a UXL. (I think that UXL will get a horn build down the road), this SI sub will be my trial run.
I just downloaded WinISD and am mucking my way through it.
But in the true spirit of DIY (at least for me), I would like to design the enclosure, instead of a tested/tried 'n true design like a Marty or a flat-pack. I picked up a few 5'x5' sheets of 18mm (3/4") Baltic Birch (sitting in my van for now.)
Wish list:
- SI HT-18D2 Driver
- Approx 28" (H) x 24" (W) x 35" (L - or deep) format
- I have decided to go slot ported, front facing driver /port. (Driver/port on 28" x 24" front face)
- 18 to 20 hz tune?
- For power, I plan to buy a iNuke3KDSP.
I hope I can ask some questions here, I know I'm not breaking any new ground. Just a guy new at this.
1. Can someone confirm my parameters are good? I don't want to get too far modeling if I am off somewhere.
2. For modeling, what is the driver volume? From reading here, I learned I have to subtract the port, driver and bracing volume to get the net internal. I know in some cases it is negligible, but I would like to do the math 1st (again, for fun). I saw on their site Displacement: 0.25 ft^3, is this it?
3. Trying to understand end correction in WinISD under the Vents section. Will I get I get better performance if none of the vent walls share the enclosure walls?
4. Port - if tuning determines I need to make a 90 turn to fit, does anyone smooth the corner with a radius? Or am I splitting hairs and over thinking it?
5. I see most slot ports have a few vertical braces. Don't you have to treat that a 3 slot ports, not just subtracting the 1.5" for the two 3/4" supports?
I think that's enough for now. Also just downloaded Sketchup, but I'm struggling just drawing a square box, so I'm pretty far from drawing baffle cutouts, roundovers, ports or bracing... Just going to be paper and pencil drawings for now.
Rob
Wish list:
- SI HT-18D2 Driver
- 18 to 20 hz tune?
Rob
