Status
Not open for further replies.
1 - 1 of 1 Posts
I have one the above cards in an Athlon XP 1700+ VIA based ASUS A7V266EX MB and SB Live! Using PowerVCRII I can record okay but after PVCR switches to a second file, the sound drops out on the right channel and there's only static. Using Virtual VCR while I can see/hear both channels okay (in stereo) as soon as I click capture, the right channel drops out. Anybody experienced this type of problem. This is using the WDM drivers supplied by Hauppauge for XP.
It occurs both on the onboard C-Media chipset sound and also with the SB Live!
Also occurs when listening to the audio output from the card directly, so not inputting back to a sound card..
Also tried vfw drivers and Virtualdub - same problem.
Thanks for any help - this is getting really annoying
Larry
1 - 1 of 1 Posts
Status
