Status
Not open for further replies.
1 - 3 of 3 Posts
Hello people,
I have to ask this question....
Is there someone using an Audiophile 2496 card with WinXp,
because I can't get the drivers to work ?
Thanks Fozzy
Premium Member
There's a bunch of us using the 2496 with XP. Are you using the latest beta drivers from midiman? They were released at the end of October, version 5133 or something like that if I remember right. What exactly is the problem that you're having?
I have this card it works great, but I think configuring it is difficult. For my DVD play back I use the coax SPDIF out. To listen to any type of Windows noise or beeps I use the analog out.
The problems I have now is that in the Windows sound applet in the control panel, everything on the first screen is greyed out.
Second problem I am having is I have a couple of Divx files that are AC3 but the sound does not get passed through.
I have the sound devices setup as Multichannel
Any help would be much appreciated.
thanks
Eli
[email protected]
1 - 3 of 3 Posts
Status
