Here are my reasons again for preferring CAT3 for voice.
1. It's impractical to just run an additional CAT5 for everything although we could end this by saying 3 CAT5s instead of 2. So George you are correct. Run one more CAT5 and conversation is over.
2. I may think I know what is happening but as in the case of Digital video recorders I may forget something crucial like Dish and D* are in the DVR business so high definition DVRs which I thought were far off are, in fact, coming to market. You guys or someone else may have information that I do not or have forgotten.
3. It is easier to sort out your wires when voice are CAT3
4. It is easier to terminate these wires at the head end- as you are going to terminate them to keystones it makes less difference that the voice wire is CAT5 but it will still be faster with CAT3.
4b. because of the tighter twists on the CAT5 it takes longer to strip and untwist.
4c Because CAT5 is more brittle than CAT3 the wire can brake without the insulation braking. This means more potential time trouble shooting.
4d If one follows the original thread, CAT5 are often punched down on 110 blocks and these are difficult to cross connect different COs. Yes, you could separate your CAT5s into voice and data and punch down the voice on a 66 block. But see 4b and 4c.
4e. CAT 5 is much more difficult to pull than CAT3 and it will kink much more quickly and easily than CAT3. Again due the tight twists it can result in broken or damaged wires.
5. You are dealing with a wire that is capable of 10mbs, which is more than ample to run most of your computer networks. How much traffic does the typical residential home network have? Many businesses can work on Ethernet networks. I am assuming here that we are referring to 4 pair CAT3 and not to 2 pair as per original category specifications.
My suggestion of 2 RG6Q, 2 CAT5e and 1 CAT3 will probably require that you use all of those wires now. DVRs require a network connection ( 1 CAT5), you may need to send audio/video back to or from the head end ( CAT5#2). You want a satellite receiver at that location but it requires a POTS connection for its internal modem.
II. You have a computer you wish to place on the network and then decide you want to add an additional network device, like a networked printer or scanner. You could add a switch but if you have two CAT5s you do not need the additional hard ware. Where there is a computer there needs to be a phone to call tech support when it fails or to setup the network. Perhaps a fax machine as well-oops- I need the additional wire.
You need the larger pipe that a CAT5 affords to handle bandwidth issues down the road. This may be your sending recorded shows from 1 DVR to an other over the LAN. You may be installing a centralized file server and than you network traffic will increase. Perhaps you will be using this network for A/V and control. This is the future. At present most people use a LAN to share an Internet connection and gain access to a few devices like printers and scanners. Ethernet is more than capable of handling all of this, including video phone- which is currently low speed; although you may be right and it could require higher speeds in the future
Again if you want to run a third CAT5 to handle voice then this is a somewhat moot issue as we are then speaking about an extra 10 minutes.
But as I do not believe that ring voltages will disappear from your home, as even in the case of digital telephone systems you must devote the wire solely to it, then you must have more than 2 CAT5s to " future proof" your home. I prefer CAT3 for the reasons I sited above. It is more than fast enough to accomplish Ethernet networks but I advise using it to carry POTS voltages. So George, you are correct. If you use a third CAT5 you will have 1 extra for future use. And all it will cost you is some extra time sorting it out form the data lines, some extra time stripping it and untwisting the pairs to punch it down to a 66 block, and maybe some time trouble shooting if one of the wires breaks while punching it down.
And what do you gain? Nothing save perhaps the convenience of not having to purchase of second type of wire. You cannot combine voice and data on the same wire so it becomes a question of using the correct wire for the job. You can use RG6Q for base band video. There will be some performance issues but it will work. So you will use 100,000 gallon tank to transport a couple of quarts of milk. It's overkill but it will work.
If any of you work in an office bring a screw driver with you to work and remove the voice/data jacks. Look at the wire that is used for voice and the wire for data. I doubt you will find CAT5 used for voice. If those guys are using CAT3 - and businesses will invest in this type of infrastructure- why do you think it inappropriate for your homes? Why are voice/data contractors making these choices? And you are correct it is not because of the price of the wire. These are typically digital telephone systems. Yet they are run on CAT3. If you guys are correct and a bigger pipe must be better why are data/Tel professionals not following your logic?
Alan
