I would look on fleebay for another remote or I think Curt may have some programmable ones too. I don't think a normal learning remote (Radio Shack) will work since the frequency for a Marquee is to high. Try doing a search in the archives i know this has been discussed before. If the 8000 is the same as an 8500 you need to go in the menu and make sure you have it set up for IR, the manual also talks about the needed changes.
