I've been doing some reading and the only clear answer I've seen is that 2 WAP54Gs bridged is a good solution. Is there consensus?
What I'm looking for is a wireless solution for a single 5xxx. I've got a wired netgear router currently for a broadband network connection.
I do archive and burn from my PC and I'll likely set it up for wireless as well while I'm at it.
I'd be very thankful if anyone with experience could illustrate the solution they came up with.
The WAP54G is currently $110 so that solution would be $250 approx. a bit much and I'm not sure it would be worth it, cheaper just to punch holes in the wall.
