Status
Not open for further replies.
1 - 7 of 7 Posts
· Registered
I got a D-Link Airplus wireless adapter and found out that it wont work with my ipaq 3670 running pocketpc2002. Can somebody tell me what the preferred adapter for the ipaq is? If someone could post a link to a list of adapters that would work with the ipaq.....Please. I would like to use my older IPAQ to control my HTPC.
· Registered
Discussion Starter · #4 ·
Thanks Guys,
I borrowed a cisco 11mbps card from work and somehow (had to specify the ip adress instead of using dynamic IP) got it to work. I will get a CF wifi card when a good deal is available.
Thanks again
· Registered
it took me about a month to finally get my wifi card to work.. its not as easy to setup as one would hope.. after doing several different things and then reseting the unit to factory default and reloading the card software would it work. then it died. a couple days later after doing nothing it started working with no problems. ppc just makes things difficult.. now the new ones with built in wifi are easy to setup..
1 - 7 of 7 Posts
Status
