I have a new set of Pioneer SE-DHP800 IR Wireless Headphones that use the TRE-D800 Digital Cordless Transmitter.
Problem is when I walk on my treadmill & try to use my headphones as soon as the treadmill starts up the headphones stop working (no sound) even though I have clear line-of-sight.
The transmitter is connected to my HDTV with the RCA connectors (red/white). Would it help if I use a Optical Digital cable?
The Headphones also came with a Coaxial digital cable but I don't see a place to connect this to the rear of my Panny TH50PZ7700U HDTV.
Other than when walking on Treadmill the headphones work fine as best I can tell.
Is there anything I can do to correct this (other than using RF Headphones)
Thanks for any help with this issue
