Anyone using a Netgear wireless setup?
I have the WGT624 wireless router and a 511T in the laptop in g mode.
All seems fine on the wired side, but with the wireless setup I'm getting poor speeds. Seems to fade in the out, the speed is not consistant.
Even with the router and the laptop in the same room.
On the router is the wireless led supposed to flash on and off every second or so?
Same on the laptop, the pair of lights just flash on/off every second or so, green in color?
Had to use g mode could not get 108 to work at all?
