1 - 3 of 3 Posts
as stated in topic title, possible dumb question... i've searched, both here and google, and either i'm not hitting the right search terms, or the product doesn't exist...
anyway...
i would like to run a zone 2 from my main receiver... i have an integrated amp to use to amplify the signal once it gets there for the speakers, so that's taken care of...
i know i can use baluns to send the signal over cat5... however, pulling wire in this house is no fun (old house with plaster walls)... plus i hate doing it
is there a wireless device that i can accomplish this with? i found several that either have amplified speakers or amplifiers on the receiving end, but nothing that just receives the signal and allows line level output to an existing amplifier...
i hope this is clear...
thanks in advance.
Discussion Starter · #3 ·
thanks for searching and replying...
yup, something like that, but for audio only, since i wouldn't be using the video part... i had found that (and a few other similar ones), but was hoping for one that was audio only and thus a bit cheaper...
but that may be a hope that will be unfulfilled...
thanks again...
1 - 3 of 3 Posts
