Status
Not open for further replies.
1 - 7 of 7 Posts
Hello everyone.
I just moved into a new condo. I have room for a great setup but not for the rear speakers. Are there places or brands that have wireless rear speakers? I don't need a whole set, just the surround sound speakers. Is this available? Are there just transmitters that plug into the back of the receiver and then send the signal to the suround sound speakers?
Thanks for your help.
Yes. There are wireless speakers and there are transmitters and receivers to make them up, as well. So far, though, all the low priced consumer examples sound pretty awful.
Kal
Originally Posted by Michaelvg1
Can you provide existing brands for me so that I can review?
Nope. Try a Google search for wireless speakers.
Which high end makers are planning to come out with them?
None that I know of.
Kal
Why do you need them? Why cant you use wired ones? Maybe we can solve the problem that you might have ruled them out.
Avoid wireless if at all possible the quality of the sound will be greatly reduced because of the nature of the FM transmition that is used.
This is the second or third time ive been ignored why they cant use wired speakers.
1 - 7 of 7 Posts
Status
