Wireless Router Compatibility with PS3
  • Total voters
    944
721 - 724 of 724 Posts
ok guys.
i have Charter cable internet and am using a Ambit modem/router wireless. I cannot stream from my windows media player to save my life. I get disconnected playing online way too often. I have upnp enabled in the router. I tried putting it in the DMZ but I can only change the last number in the static IP address? I have NAT2 and UNPN enabled on the PS3. Tried port forwarding, but again, I cannot put in a static ip address..for example. 192.123.1.10, cannot change the "1", only the 10.
My PC sees the PS3, but it will not find my PC? I had a netgear modem before moving an had no problems at all, so I am assuming it is my modem? I cannot think of anything else to do. HELP!!!
Well the issue you have is with DLNA and video streaming and not with network connectivity.
I would recommend downloading the PS3 media server and see if you turn that on, if your ps3 can see it or not.
Don't mess with the IP address, I don't think you know what your trying to accomplish. If all your computers are on the 192.168.1.x subnet, then everything will work out fine. Leave it on DHCP and don't do static.
Good luck.
-Splints
Thanks splinters.
I just said the hell with it and used a wired connection and it found my pc instantly...as well have not been booted from KZ2 either.
Still don't get it though...I had between 95 and 100% signal strength.
