1 - 1 of 1 Posts
Hi All,
I have been looking around to get a sound dock to stream music of my iPhone. I realized that best of the stuff is pretty expensive and the usual suspects are probably not going to satisfy me.
I realized that I can probably do a wireless DAC + Speaker combination, this way I can stream music of my laptop and use the iPhone as a remote app as well or connect the Phone directly to the setup.
I need recommendations and/or advice on what can be an ideal combination. I am okay to spend around $400-$500 for the setup.
I prefer a balanced, transparent and clear sound (to the last ting). Not really looking for very big BS speakers, something small would be ideal.
Thank you.
1 - 1 of 1 Posts
