hey guys, I’m trying to figure out a way to use my Focal Chora 806 bookshelves wirelessly as my surround speakers. The problem I am facing is I have just moved into a new place and the wall where my tv and front stage is placed is not connected to any Of the other three walls in the room. The room is as if there is a rectangle with three sides and the fourth side is disconnected due to opening to other rooms on each side of the wall. This has left me with no attractive way to run wires to the rear of the room. The only solution I can think of would be to use a wireless transmitter of some sort (I think SVS makes one) and a two channel power amp set up in the rear of the room. The next problem I run into is I would need to find a pretty small form factor power amp as it would need to fit into a square shaped cubby that I have open in one of the pieces of furniture next to my couch. I don’t want to supply the speakers with crappy power though and it seems tough to find something nice in a small form factor like that. Any ideas for how this would work, a wireless transmitter that is good for the job, and a small factor power amp that still provides a reasonable amount of clean power? As the final point, I also don’t want to spend to much on this as running wires is what i would normally do but it just won’t work.
