Status
Not open for further replies.
1 - 4 of 4 Posts
Looking at the spec sheet for the panasonic 711xu, I see that it has 2 vga inputs. What is the correct way to connect a prog scan dvd player to this pj?
1) a simple 15pin-->3 rca breakout cable
2) component cable from dvd --> transcoder then: 15pin--> 15pin vga cable --> to 711xu
if #2 is best what does the transcoder do ?
Yep...first option is better.
By "transcoder" do you mean line doubler or scaler, perhaps? If it's ONLY transcoding a Component (Y, Pb/Cb, Pr/Cr) signal to a VESA standard computer monitor resolution, it's an unecessary additional electronic step.
Even most line doublers will not improve on the picture-quality vs. component-p (progressive) output straight from the DVD player.
1 - 4 of 4 Posts
Status
