1 - 6 of 6 Posts
I used to be able to plug in my Coax to my PC and watch about 80 channels of "basic cable". Now that Comcast is forcing the use of Digital Adapters in my area, I only get about 10 channels.
So, how do devices like HomeRun or SageTv work with PCs that accept COAX?
Not as well as they used to with Comcast. But just as good as they do with other services.
The HDHomeRun is a clear QAM tuner, and the limited basic channels on Comcast are still clear QAM, so there is no change there. For analog tuners and the old analog channels, you would need to connect the tuner to the DTA box and use an IR blaster to control it. Alternatively, you could get a CableCard tuner like the Ceton 4 tuner which is sort of available now (if you want to wait 3 or 4 months for it to ship), or the HDHomeRun Prime 3 tuner, which is supposed to be available sometime soon. You would have to use Windows Media Center to get all the channels with a CableCard tuner, though.
I just got a flier with my comcast bill.
There are three classes of channels that come with "Limited basic"
Limited basic: These are analog channels, these will be moving to the "Limited Basic digital channels"
Limited Basic Digital Channels: These are standard definition channels in clear QAM
High Definition Limited Basic: These are the High Definition local over the air channels in clear QAM.
The HDHomeRun receives only clear QAM and 8VSB signals, it does not handle analog. So in the case of the HDHomeRun, the situation is improving as the analog channels will be moving to clear QAM.
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
The only channels in clear QAM from Comcast will be locals (SD & HD), gov/edu/public service, shopping, and in most areas one or two others like WGN America (HD in the Detroit area) or TBS. This is Comcast's definition of Limited Basic service.
Everything else SD & HD will be encrypted.
I just went through the list that Comcast included with my bill to compare it with what I actually get with limited basic:
Code:
Code:
key:
*               Channels I get that comcast does not say I should get
?               Channels that comcast says I should get in analog, but don't, or if alone there is no comcast channel number for it
***             Channels I don't get that comcast says I should, and according to scte65scan are being broadcast in the middle of the limited basic filter.
+               Digital channel I get but comcast does not mention
-               Channels Comcast says I should get but don't
LIMITED BASIC
89-1            2   KTVU-2 (FOX)
92-1            3   KNTV-11 (NBC)
89-2            4   KRON-4 (IND)
89-3            5   KPIX-5 (CBS)
92-2            6   KICU-36 (IND)
89-4            7   KGO-7 (ABC)
89-8            8   KTSF-26 (IND)
89-5            9   KQED-9 (PBS)
92-4            10  KTEH-54 (PBS)
85-9            11  HSN
89-10           12  KBCW-44 (CW)
89-7            13  KOFY-20 (IND)
89-6            14  KDTV-14 (UNI)
100-9387        15  CreaTV San Jose
100-9388
92-5            16  KKPX-65 (ION)
90-4            17  KCSM-60 (PBS)
92-3            18  KSTS-48 (TLMD)
89-9            19  KTNC-42 (IND)
90-5            20  KFSF-66 (TF)
85-1            22  C-SPAN
85-10           23  QVC
100-9395        24  KSBW-8 (NBC)
90-6            25  KTLN-68 (IND)
100-9389        26  Civic Center TV
100-9392        27  CCN 1
100-9393        28  CCN 2
71-3            29  Discovery Channel
100-9397        *30 CreaTV?
90-2            32  KMTP-32 (IND)
87-4            33  WGN
94-9            *62  History
98-3            ?76  Shop NBC
                *97 Civic Center
LIMITED BASIC - DIGITAL CHANNELS
90-3            21  KCNS-38 (IND)
94-11           +67 HGTV
120-14          103 Leased Access
100-9391        104 Comcast Hometown network
107-13          108 California Channel
85-2            109 C-SPAN 2
100-9394        111 TV Guide Channel
63-7454***              173 KTSF-KBS (Korean)
95-9551         174 KTSF-NHK
95-9552         175 KTSF-ICN
79-2            186 KNTV - Plus
79-3            187 Universal Sports
78-3            188 LATV
80-3            189 KQED - Encore & Life
90-8            190 KQED - World
90-9            191 KQED - VMe
90-10           192 KQED - Kids
80-8            195 KGO AccuWeather Now
96-6            196 KSTV-32 (Azteca)
119-3           197 KEMS
96-1            199 KFTY-DT (TV50)
87-7            ?   Jewelery Television
98-11           1   Preview
100-1           ?   dead
98-12           ?   Color Bars
98-13           ?   Liquidation Channel
100-9390        +26 Government Access
123-40          +116 Comcast Sports Network
HIGH-DEFINITION
78-2            702 KTVU HD (FOX)
79-1            703 KNTV HD (NBC)
74-1            704 KRON HD (IND)
78-1            705 KPIX HD (CBS)
119-1           706 KICU HD (IND)
80-1            707 KGO HD (ABC)
80-2            709 KQED HD (PBS)
31-8154         710 KSTS HD (TLMD)
79-6            711 KKPX HD (ION)
74-5            712 KBCW HD (CW)
31-8152         714 KDTV HD (UNI)
80-7            715 Live Well HD
31-8153         716 KFSF HD (TF)
                -717 WGN HD
All of the analog channels are also available via clear QAM.
Note that there are two channels that Comcast says I should get but don't.
KTSF-KBS is interesting in that it is included in limited basic, but its frequency is in the middle of the limited basic filter making it impossible to get for limited basic subscribers. This is an OTA channel, so it should be in the clear. I'm not missing it much since it is in Korean, and I don't speak Korean.
The other one is WGN HD. I do not know what frequency this is on since it is a HD channel and the mapping that scte65scan gets is for the cheapo SD set top boxes so it does not include data for any HD channels. This channel might actually be worth having.
1 - 6 of 6 Posts
