Status
Not open for further replies.
1 - 7 of 7 Posts
I can *barely* pick it up here in Massachusetts. My antenna is pointed slightly east-south-east for the Boston stations, so not directly at it. However depending on the conditions, I can get about 40 - 60% of the signal.
-Mike
Originally posted by thedoctor
WMUR is back,the only problem is i can't lock on here in Weymouth,Mass.with my rat shack outdoor antenna and my dish 6000.Are they using low power?
WMUR-DT channel 57 is at full power as far as I can tell, at 537 KW ERP.
Since you are in Weymouth you may be a bit too far. check a map. The WMUR -DT transmitter is very close to Manchester NH. In Weymouth you are probably quite a bit further than the normal 60 miles for UHF.
Do you currently get channels 9 and 11 which would reach you easier, at their lower frequencies?
I would estimate WMUR to just about reach Boston or Worcester at max range if your location is good. I know signal is good for me in Lexington, and I know it reaches Framingham too, but may not reach low spots there.
1 - 7 of 7 Posts
Status
