The Infinity models very well for me in a 17Hz TH. Excursion might be a limiting factor there, though.
Originally Posted by stgdz /forum/post/19165807
Looking at the LAB 12 driver it looks really close to what danley uses in the DTS-10. Since it is made by emminence did they just up the X-max on it and lower the FS a bit?
Originally Posted by Bill Fitzmaurice /forum/post/19168386
If a change was made in Fs chances are it was made higher.
Originally Posted by lilmike /forum/post/19167898
I've looked at that driver. Take that 96 dB with a grain of salt, it is measured at 2.83V, which is a 4-watt number with a 2-ohm (dual 4 ohm coils in parallel) driver.
Originally Posted by lilmike /forum/post/19167925
Yup, the excursion blows up as power is applied. 16 volts takes it over xmax at 23 Hz. Only makes 110 dB.
Next....
Originally Posted by stgdz /forum/post/19168970
well I wasn't aiming for something super deep or loud. I all ready had a 24" THT with a 15" driver, I didn't have enough room for an additional 24" so I built a smaller one and tried to pick out a cheap driver as I couldn't rationalize spending the money on a 12" DVC that was close to in price of the 15" DVC.
So I set a price of about 60 bucks for a driver and originally found the 1252w's below that price(they were used in Passing Intrests build) but after digging around a bit more I found the 1262 so I went with it. The driver was cheap($60) and it met most of the requirements I was looking for. It balanced out the horrible room I currently have though.
That 8x quatro setup that maxmercy posted sims for looks really tempting but that would mean I have to get new amps, more subs, and build more boxes but it would get me into the unicorn territory of below 15hz.
Originally Posted by lilmike /forum/post/19169612
hence the "Next....".
