Originally Posted by Oklahoma Wolf /forum/post/19198051
Originally Posted by lilmike /forum/post/19265933
The drivers are well within a 1/4 wavelength at the frequencies we're working with. At 20 Hz, a single wavelength is on the order of 17 meters, so a quarter of that is 4.25 meters.
As designed, these drivers will nearly be touching. They'll effectively be a point source until the distance between their acoustic centers is over 1/4 of a wavelength. For easy math - let's say the drivers are 30 cm center to center. 30 cm X 4 = 120 cm or 1.2 M, which is the wavelength of 286 Hz, well outside our band of interest.
So - in a nutshell, it won't matter at all so long as the drivers receive equal power and are driven in phase.
Originally Posted by tg3 /forum/post/19266225
As a test, I recalculated the parameters by adding 30 cm (the center offset of two drivers close together) to L12 and L34, and subracting 60 from L34. Sure enough, the results were almost identical.
However, when I run the sim with only one driver (TH 1), the results are very different (not as smooth). Why is that?
Originally Posted by lilmike /forum/post/19266316
The driver needs to be loaded by the horn - you've got one driver in a horn sized for two, so it is severely underdamped.
Originally Posted by tg3 /forum/post/0
Got it. And how can you tell when a driver is properly damped (aside from the FR)? Surely the Sd/S2 compression ratio is important.
Many thanks!
Originally Posted by LTD02 /forum/post/19269821
i wonder how important the impulse response is as a practical matter. i've listened to the impulse response of some really good pro audio drivers that sound almost like a chirp, while others such as the tht sound more like a "whoomp" with lots of after resonances. in practice though, the tht is generally reported to be a very clean sounding device.
when you say, "I just go by the FR." what specifically are you looking for/at?
Originally Posted by Oklahoma Wolf /forum/post/19270068
I call it the boing-boing-boing effect
Originally Posted by BeerParty /forum/post/19270473
You guys are going to have to cut down on the high tech terminology, you are losing us amateurs with all this techno-speak.![]()
