Hello all. I've been toying around with a couple different antennas from RadioShack. Both antennas were pre-amp indoor/outdoor and relatively cheap ($20-$30). They worked for the most part, but the reception was good only 75% of the time. Obviously, this has frustrated the wife and I now have to act quickly to resolve the issue before football starts next week.
So, I ended up purchasing the Antennas Direct ClearStream4. Probably a rash and expensive decision, but had to act quickly. Anyway, have a couple questions.
1. If I install this antenna on our chimney on the roof will it require grounding wire? Are there rules on when this is required or not required?
2. Since I could receive most channels with the cheaper antennas, but the reception was unreliable, does that mean an amplifier would have solved my signal issues?
As a reference, this is my TVFool report . Transmitters range from ~20-30 miles.
Thanks everyone.
Thanks everyone.
