I'm looking into options for a subwoofer for my garage I'm having built. The garage is 26'x26'x9'6". The sub will be used primarily for music but I am also planning to put a projector in there so there will be some movie use as well.
I am thinking I either want sealed or something that has a grill over the ports to keep the random vermin out. It does not need to be perfect sound quality since it is a garage.
For my speakers I am thinking about using a set of JBL studio 530s I have sitting around that I was planning to use as surrounds for my HT system.
Options I am currently considering are:
Any thoughts on if the MFW15 driver is worth the time and effort to build around? Any other ideas? Trying to keep this project around $500 or so.
- Using the 3CF knockdown kit from PE and a 15" MFW15 driver I have sitting around (I upgraded to the turbo package so I still have the old driver) and buying a 500w plate amp.
- Buying the 3cf knockdown kit and DA 15" Ultimax from PE plus 500w plate amp. (most expensive option)
- Buy one or 2 BIC 12" subs
- Put some sort of PA sub in there like a Behringer VQ1500D (this only goes down to 45hz)
