IMO, not worth the hassles unless you're upgrading screen quality as well.
Originally Posted by bqmeister /forum/post/0
I agree, not worth the hassle, unless....
An upgrade is an upgrade. If you have a buyer for your 114" screen and can help defray most of the upgrade costs, go for it. It'd be a shame to have a 114" screen sitting on the floor unused though.
Is 118 the biggest you can go? If you could maybe do 124-126, it might be a more worthwhile bump.
Originally Posted by caesar1 /forum/post/0
I was hoping I could possibly work something out with Carada for my current screen, since I've only had this screen for a couple of months.
The next step up with Carada (after 118) is 126 inches. Unfortunately, with my ceiling it wouldn't work too well. My ceiling is only 7' 9" -- so the screen would be too low to the ground with a 126 incher. (the 126 inch screen is 68 inches high with the frame). Leaving only about 2 feet of wall space.
I have a 2nd row on a 10 inch riser -- so I like the viewable part of the screen to start at about 30 inches high off the ground.
Originally Posted by Rayboy /forum/post/0
In case you didnt know, you can have Carada CUT the 126 inch down (if something in between 118 and 126 would maximize your space.) I think all the screen makers do this for a nominal fee. I have a Da-lite hi power, electric. They cut one that was a little too big down to my specifications.
Increase your riser.
I've got just over 20 inches from the bottom of my screen to the floor.
I'm way further back than you. Front row is about 18-19 feet back. Riser is 12 3/4 inches high.
