Status
Not open for further replies.
1 - 2 of 2 Posts
Not to beat a dead horse but, still having problems getting 119 bird. It appears that with my current setup, my line of sight to the 119 bird is obstructed by numerous telephone wires. Would this affect the signal? My 101 comes in OK because the tilt aims the line of sight over all the wires. But the 119 tilts it down right through them.
Mike
Mike, Yes, the wires could cause problems. Use the sun and info below to see if you have a clear shot at the 119° satellite. Conversely, if there is shadows on or near your dish, then you may have problems (be sure to account for the sun's angle). Do not use the info for aiming your elliptical dish
Zip Code: 63031 PO Name: Florissant (MO)
Population (1990): 52659
Longitude of Satellite in degrees:119
Your longitude in degrees:90.3
Your latitude in degrees:38.8
Time Zone: Central
Azimuth of Satellite: 221.1°
Elevation of Satellite: 36.1°
Monday, April 30, 2001
Sun is 24.5° above sat position at 2:16pm CDT.
Saturday, May 5, 2001
Sun is 26.2° above sat position at 2:12pm CDT.
Saturday, May 12, 2001
Sun is 28.5° above sat position at 2:06pm CDT.
Wendell
Technical Services Supervisor
MAETV
[This message has been edited by Wendell R. Breland (edited 04-29-2001).]
1 - 2 of 2 Posts
Status
