Status
Not open for further replies.
1 - 11 of 11 Posts
Anyone know the reason for the switching of the channels? I'm curious, but can't complain, I now recieve WTVG instead of a black screen. Will WNWO also be doing this?
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
Not sure what you mean. I checked all 3 Toledo DTV stations tonight and they all seem fine.
WTOL
17-1 CBS HDTV
17-2 CBS SDTV
WTVG
19-1 ABC HDTV
19-2 ABC SDTV
19-3 Weather Radar
WNWO
49 NBC HDTV
Discussion Starter · #3 ·
The WTOL and WTVG stations were as you listed them about a week ago, now they are:
WTOL:
11 analog
11-1 HD
11-2 SD
WTVG:
13 analog
13-1 HD
13-2 SD
13-3 radar
WNWO
24 analog
49-2 HD
Before the channels switched to the above, I could get a picture from WTVG in HD, just a black screen, now everything is crystal clear.
The stations haven't changed anything.
You must have switched your STB from the digital channel numbers (which I'm referencing above, 17, 19, 49) to the re-mapped analog ones (11, 13, 24)
Actually, I noticed this to. For some reason WNWO isnt remapping to 24 anymore, but 49. The problem I was having of the audio dropping out when they switched from local to live feeds during ER was gone as well. The last 15 minutes were black, but that sounds like a national problem from reading other threads here.
Discussion Starter · #6 ·
last night i did a channel search to make sure i wasn't going nuts, and guess what! 49-2 WNWO HDTV is now 24-2. Whatever happened, it happened by itself, or there is a techie ghost in my house who likes to watch TV.
What STB's are you two using?
Discussion Starter · #10 ·
i found in the TV menu, an item to switch the channel guide on and off. i must have turned it on recently and that grouped the stations together. if i turn it off, it reverts back to 17,19, and 49.
Way to go!
1 - 11 of 11 Posts
Status
