Status
Not open for further replies.
1 - 6 of 6 Posts
· Registered
I'm receiving my X1 tomorrow and I'm a little confused as to how I can get 480p to the X1. Is the only way to do to run an S-video cable from my dvd player and have an s-video to VGA adaptor so I can use the 480p capability of the VGA connection on the X1?
· Registered
Discussion Starter · #2 ·
Perhaps I've asked the wrong question?
What connection should I use to get the best picture quality out of my Infocus X1 projector? As far as I know,and I may be wrong, if I use the component video connection I can only get 480I. And the only Input on the X1 that takes the progressive scan is the the VGA connection.
· Registered
i think you should post this in the
· Registered
Discussion Starter · #4 ·
You know, your absolutely right.
· Registered
np - looking forward to hearing what you think of the x1! the carpet's going in for my basement re-model on Friday and an x1 (or other) isn't far after that. post soon! ;-)
· Registered
Discussion Starter · #6 ·
No problem, I'll let you know how things turn out.
1 - 6 of 6 Posts
Status
