Status
Not open for further replies.
1 - 2 of 2 Posts
I'm all set up for HDTV via comcast HD..I thought I had read threads regarding optimal settings but am unable to find them now. Any help on settings of the X1 and the output of the cable box would be appreciated..
Banned
The X1 will handle any resolution the cable box is outputting. I would set to either 1080i or 720p, whichever looks better. Lots of people don't like the picture of non-HDTV coming over the VGA port (which is the only connection that handles HDTV), so what they do is connect the component/VGA for HDTV and an S-video cable for other channels. You can toggle between the two sources with your X1 remote.
1 - 2 of 2 Posts
Status
