Be sure the cable box is outputting at 480p, 720p or 1080i. It won't work if it is outputting 480i.
What brand of box is it? If it is Motorola, the settings are available by turning the box off, then hit the Menu button. I suggest you do this while it is connected to your TV rather than the projector, it will just be easier that way in case you select 480i at some point.
p.s. The VCR cable probably is not a good idea. Get a proper component cable. Running 480i from the DVD player is one thing, but 720p and 1080i use much more bandwidth and are more likely to suffer from a poor cable.
