Status
Not open for further replies.
1 - 4 of 4 Posts
I am having problems with my new X1 thinking that it lost the signal from the computer input and going to the blue screen. It happens quite often, and is very irritating.
Any one else had this issue, how did you fix it? Thanks.
Banned
If it happens while you are watching DVD's it may very well be a sync issue. The way to fix it is to download the 4.1 firmware if you have an older version, and check off the new box for Sync.
Every time that your computer changes resolutions the projector will go to blue screen while it resyncs to the signal again. Is this happening during the boot process? Or while starting a game or when a game is switching to a cutscene? That would be normal.
Discussion Starter · #4 ·
It happens when watching TV, with an HDTV turner mostly.
or when using the computer and watching a video on it, never with the DVD player though(not yet at least).
It seems to happen a lot when the image on the screen goes to a mostly white image.
1 - 4 of 4 Posts
Status
