Status
Not open for further replies.
1 - 4 of 4 Posts
I just received my X1 and I have a question. I have a question about the remote. It seems that the remote has to be pointing directly at the front of the projector to work. Since I will be ceiling mounting the projector and it will be in front of my seating position, I am not sure how much of a problem this will be.
Does anyone else have this issue, and if so how did you resolve it.
Dave
I've had my X1 since June...
It's mounted just about directly above my seating location. No problems with the remote not working. I just point it at the screen (DIY Parkland) and the signal bounces back to the X1's IR receiver just fine.
Hope that helps.
Dan
Discussion Starter · #4 ·
Thanks, I have it on a coffee table now and the signal was not bouncing of the front wall and hitting the projector. I will try it again when it is mounted and I have a screen.
Dave
1 - 4 of 4 Posts
Status
