Don't you see the colour banding on your ATSC / Sat/Cable HDTV or are you only into "pristine" DVD for testing? |
I assume you are addressing this to me.... No, I don't see color banding in any environment. Color banding is often exacerbated by the use of certain display technology. It can also be caused by using older combinations of drivers and decoders.
I use TT for media playback in software decode mode with ffdshow doing a Lanczos 2 resize and the DScaler 4 sharpen filter and see no color banding at all on any sources. I have also tested using DXVA hardware mode, and in that case the difference between the two cards is even greater. I don't use my HTPC for ATSC/Sat/Cable, which I rarely watch in my HT anyhow. DVD, WMV-HD and HD-DVD are my sources of choice.
Your test - which I've read was not what I would have done to prove definitely for myself. |
Not sure what you are talking about? My test simply consists of playing the same source material on both PC's and pressing a single button on my remote to switch the projector inputs. It could be anything from a DVD of "Moulin Rouge" to any one of a number of test patterns on DVE Pro or any one of several other calibration discs. Or it might be a WMV-HD disc like "Coral Reef Adventure". Of course both players and both projector inputs have been calibrated using DVD Pro's test patterns before testing. Any differences in image detail, color ringing etc. are very easily seen.
Former owner of Radeon now owning an nvidia which is inferior IMHO. |
Then why do you have the NVidia in your system now?
I have 2 identical PC's one with the 7800 and one with the X1900. The only time I'll ever use the ATI equipped PC is after a new driver comes out to see if ATI has finally eliminated their lack of fine detail and reduced the ringing around any hard edges in the image.
So far, it hasn't happened. What I am treated to is the challenge of making the new driver work properly at 1080I with my Qualia. The X1900 is certainly an improvement over the X1800, which couldn't output a proper 1080I signal over DVI. But it still takes me 4 to 5 times as long with the ATI to get a custom 1080I resolution that survives a reboot.
Edit: Just read the other thread about the color banding issue. I don't know if this is why I dont see it, but I use MCE2005 in my HT systems because it's the only way to get all the DirectShow fixes available from MS. For some reason, certain modules were never released as patches for XP. I also never mess with the desktop color and level controls in the video CP, preferring to calibrate my projector's inputs to the standard default DVI outputs of the video card. Maybe that explains why I never see your banding issue????
Vern
