Xantech IR system and Stewart screen
302 Views 1 Reply 2 Participants Last post by  jrivera
Hi,
I want to use a Xantech infrared distribution system to distribute all control signals for my home theater. So I just ordered a Xantech 490 kit with an IR receiver, a control box, four emitters, and a power supply.
I'm planning to buy a Stewart Model A Electriscreen and want to control it with the Xantech. I know you can get an IR control package from Stewart, but it has its own IR receiver and I want to have the Xantech receiver drive it instead. What's the right way to hook this up:
1) Can I drive the 12V screen trigger input of the projector with the output of the Xantech control box? (X sensor -> X control box -> S screen trigger)
2) If I buy the Stewart low voltage control box, can I drive the low voltage input with the output of the Xantech control box? (X sensor -> X control box -> S control box)
3) Or should I do the thing that seems silly, but I know will work: buy the Stewart low voltage control box and infrared sensor, and drive it with an infrared emitter out of the Xantech control box? (X sensor -> X control box -> X emitter -> S sensor -> S control box)
4) Or is there an even better solution?
-Mike
Status
Not open for further replies.
1 - 2 of 2 Posts
Dear Mr. Anderson,
You seem to know what you are doing.
Your answer # 3 is correct. Buy a Stewart IR Control and follow your answer # 3.
Joaquin Rivera
Stewart Filmscreen Corp.
1 - 2 of 2 Posts
Status
