Status
Not open for further replies.
1 - 9 of 9 Posts
The component video cable should be just fine and produce the same quality. However, it doesn't hurt to know what TV you will be using.
That's kind of up to you, if you want to spend the extra $40 for a potentially marginal improvement. How big is your screen? If you have a large display, VGA will make a difference over component, but it's still analog so there's not going to be a huge leap like with DVI or HDMI.
youll probably see a little bit better picture, depending on the TV, using VGA. i plan on getting the VGA connection just so it frees up a component input on my TV, but you will still get the 720P or 1080i resolution through component.
Banned
on my set it really depends on the device that is sending out the signal as to what is better , Component or DVI/HDMI.. regardless component and DVI are so close that I doubt anybody would be able to tell the difference.
Discussion Starter · #6 ·
its a Philips HDTV 26 inch, so its not something massive
i was just woundering which will be the best approach
Discussion Starter · #8 ·
and thats the one that comes with the bundle deal which i should be fine with then
but why does it have so many ends, i am sure my tv has only 3 slots for the ends
It's a multi-purpose cable that does component and composite, as well as analog audio.
1 - 9 of 9 Posts
Status
