1 - 5 of 5 Posts
Here is a wierd problem I have experienced: Every so often, for no good reason, the drive will either turn off or drop the USB connection, then it turns back on after a second or two, and is immediately recognized by Windows and is back working again.
This is no big deal if I'm not playing an HD DVD. However, when this happens WHILE playing an HD DVD, this is a big problem because PowerDVD stops playing, and the movie has to be restarted from scratch.
Has anyone else encountered this momentary dropping of the USB connection with this device? Is this a problem with my drive or the USB subsystem of my computer?
Discussion Starter · #4 ·
I solved the problem. Believe it or not, I had a bad USB extension cable so the contacts were loose and this caused the XBOX drive to turn off and on which of course would stop the movie from playing...
1 - 5 of 5 Posts
