1 - 7 of 7 Posts
It is possible.
The Xbox 360 if I remember correctly has a VGA cable available for purchase, but I'm assuming with built in you won't be able to use that. Or possibly if there's would be a connector you could purchase OR you could wire it yourself, shouldn't be too hard.
Otherwise you can get a component to vga box. I personally own this one . I use it for my Wii and it works fine, assuming the game is 480p.
Here's a guide/review . Read that and decide yourself ig you want the product. It's ugly, yes, but it's small and one of the cheaper ones, I just hide mine and never have to see it.
It also comes with a cable into which you can stick the two audio sources, this can be used as an extension lead for the audio or if you want you can hook a normal two-pc speakers up to it.
If you don't get that go ahead and ask for a photo.
Discussion Starter · #4 ·
Yeah ill look into it, but since my monitor has the built in cable, which has a male vga end, would i be able to get a gender changer that would change the end to female so i could plug in my xbox vga cable?
Actually, you don't need to get one. The cable actually comes with both a gender changer and an RCA-to-mini-stereo plug adapter, so you should be all set right out of the box.
Red pyramid is right, buy the VGA cable and it comes with the male/female adapter plus it makes your 360 an upscaling DVD player.
1 - 7 of 7 Posts
