1 - 20 of 51 Posts
Discussion Starter #1
Hi, was thinking of doing the above for playing games as im sick of wires trailing everywhere. However, after doing a search of the forums ive noticed people with problems saying it doesnt work if there are other usb devices plugged in, or that it needs to be on a USB PCI card? Is this still the case?
Also, would i need the xbox controller for windows or would a regular one work with the gaming receiver? And is there a 'windows' gaming receiver or is it just one for both the xbox & PC?
I haven't had any problems with my wireless gaming receiver. I have it plugged into a usb port off the motherboard. I only have 2 devices plugged in to my usb ports on that machine though.
I believe the pc xbox 360 pad is wired so you don't want that one. You will want a wireless xbox 360 game pad.
Lastly, there is only 1 wireless gaming reciever which is for the pc. The xbox has the wireless capability built in already.
I use the Xbox 360 wireless game pad on my PC and it works great for latest Tomb Raider games and Resident Evil 4.
You will need to buy the Microsoft Xbox 360 Wireless Receiver for Windows (and have an available USB port) and the wireless game pad.
And as Richard713 stated, the wireless receiver works fine, even on a USB hub with other equipment plugged into it.
Discussion Starter #4
sounds good then! Ive got quite a few usb things plugged in to both onboard usb & into a PCI USB card, so as long as it all works! Only other thing, ive got a bluetooth 2ghz keyboard & mouse, that wont interfere in anyway will it?
Nope! I use a Logitech Bluetooth keyboard and mouse. No interference problems.
I have problems with mine & USB power. I can't have ANY other USB device plugged into my HTPC if I want the xbox wireless receiver for windows to work, even though the USB power consumption is below maximum. I run it in conjunction with a PS2 mouse, and it works flawlessly.
A USB PCI card or externally powered USB hub will fix the problem.
I was one of the people that had issues with this.
I had a bluetooth dongle for mouse and keyboard, usb hard drive and a wireless receiver for 2 wireless ms 360 pads.
I used to get intermittent problems, so I borrowed a pci usb adapter (as they're not all that easy to find nowadays) and plugged the wireless receiver into that and everything was ok.
It could just have been my motherboard or 2 ms wireless pads is just pushing it?
I'd advice using the pads without a pci or powered usb hub just to test and if you get problems like dropouts then consider a pci card or powered usb hub.
BTW - The 360 pads are great, i'd recommend getting a couple with some rechargeable batteries.
I just got me controller, seems to work ok so far. Does anyone have a list of what games support the xbox controller under windows? I know support game pads but I am more looking for native support of the device in what games I can look at buying.
Thanx for the info.
Afaik, anything that says Game For Windows on the box has support for the pad out of the box, meaning you don't need to config the buttons or whatever, it should be just like a console game.
off the top of my head, tomb raider legend and anniversary, resident evil 4, psychonauts, half life 2+ep1+ep2+portal, outrun 2 and coast to coast, colin mcrae dirt.
I've played lots of games with the 360 pad on the PC, and i've never met a recent title that didn't work.
I bought "The Witcher" thinking because it was "Games for Windows" it would support the 360 controller. It did not. Seems to me they should not have been able to call it a games for Windows title without native gamepad support.
Discussion Starter #11
just waiting for it to arrive now, ill try it on both onboard usb or on the pci card ive got! Cheers for the help
If you use it heavily you may want to consider the recharging dock or getting a rechargeable battery charger, they pay for themselves after a few months.
let me tell you about the wireless usb adaptor for the pc. If you have both an xbox and a pc it turns into a nightmare as if your pc is close to your xbox it will turn on your xbox and the xbox has rights to the controller over the pc.
No it doesn't.
Once you sync the controller to either the 360 or the PC it will only connect to that device.
I have two controllers, have one sync'd to my 360 and one to my PC and turning on my PC controller does not turn on my 360.
On the Games for Windows topic, apparently all it has to support is the wired controller. Maybe they'll require new games to support the wireless as well, but I wonder with The Witcher not supporting it properly. This was discovered because Rainbox Six: Vegas is GfW, and supports the wired controller fine, but not the wireless controller.
Originally Posted by krimson /forum/post/12460830
No it doesn't.
This poster is correct.
Is there any PC game that supports rumble on the Xbox wireless controller (or the wired one for that matter)? When last I looked, the Microsoft website said the rumble feature would work with certain games, but failed to mention which ones.
I just checked Bioshock and Crysis. Both support rumble with the wireless Xbox 360 controller. Game developers' websites would probably be good places to look for this information as I am not aware of a comprehensive and up-to-date list.
i wanted to use my (regular) x box 360 wireless controller for my pc,for games or to use as a mouse ,what i did was plug it in my pc usb with the play and charge kit and turned it into a wired regular controller , i think , i read that theres a way of turning the regular control as a windos control without having to buy the windows one it cost alot more, i dont know hot to do it and what drivers to use please some one help me and to make the problem worst i downloaded a driver from the microsoft site and it didnt work and now i cant unistall it from my controller i unistall it and restart the computer and its still there.some one please help me!!!!!!!!!!!!!!!!!!!!
1 - 20 of 51 Posts
