Status
Not open for further replies.
1 - 2 of 2 Posts
Discussion Starter #1
I've been looking around for a while and have been stumped. A/V bewilders me ...
I want to hook up my xBox to my Dell 2005FPW. Video works fine since the monitor takes component inputs.
But how would I hook up audio from the xBox (component) to a speaker system or headphones?
Any help would be greatly appreciated. Thanks!
Premium Member
Not sure what you have for a speaker system for your PC but if your fortunate enough to have one of the higher end Logitech 5.1 systems they all take an optic cable which you can run from the 360's HD cable to the Logitec "controller" to get sound. I've used my 360 with a couple of different PC speaker set ups with good results.(Z5500 & Z480 systems)
Good luck.
Cheers
Calvin
1 - 2 of 2 Posts
Status
