Hi Folks:
Can you tell me how I could best connect an xBox to my Marquee??
I'm currently enjoying my Marquee 8500 connected to a HTPC by RGBHV cable. The video card on the HTPC is modded with clarity circuit to ouptut RGBHV. The video card also has a second output - a VGA, and I have a VGA/DVI adaptor to output DVI. Also, my PC has a Fusion II HDTV card, so I can input SVideo to the PC.
Is there a special cable I can get that would connect the XBox to the SVideo input on the HTPC (would be convenient, if not the best quality, as I could leave things connected, and get up and running with minimum hassle), or is there a cable I could use to connect the xBox directly to the Marquee (which only has one input - the RGBHV, so I guess I'd have to swap out cables moving from DVD to xbox).
Please advise. I can't think of the right solution, as the Xbox seems to use strange cabling. Also, while there seems to be some AV cable upgrade for the xbox - it seems to be an RGB upgrade - so then would I need an RGB/RGBHV adaptor or something to get that working? Overall, I'm looking for the minimum setup hassle, coupled with maximum picture quality (if that's possible). Thanks in advance for any and all advice!!!
John (CRT Newbie).
John (CRT Newbie).
