1 - 4 of 4 Posts
Those who connect via wireless with your XB1, does it make much of a difference if I am connection to my 2.4GHZ vs my 5.0GHZ wifi? Reason I ask is I get a stronger signal with my 2.4GHz. Not sure if both will produce the same results with Netflix/Online Gaming or not.
Discussion Starter · #2 ·
Connecting to my 5GHZ, detailed network connection on xbox one tells me that my wireless strength is 51%, latency 60ms. Not sure if that is acceptable or not.
Discussion Starter · #3 ·
Any input on this?
2.4 has a longer reach compared to 5. Wired is best if you can swing it.
If your Xbox is close to the router , try 5.
1 - 4 of 4 Posts
