Status
Not open for further replies.
1 - 3 of 3 Posts
I am sure its been asked before but I don't have time to go and search through the history of this forum. Is mad catz the only maker of a steering wheel for the XBOX? If not what other ones are out there? And what would you suggest?
Rev
Or try google.com
I'm not trying to be a smartass but posting on a message board is not like talking on the phone, you will not get an imediate response when you ask something. It took over an hour for someone to respond, in an hour you could have looked online for different wheels, called a few stores to see if they carry what you want, went & picked it up & be home playing with it.
FWIW there is not a good choice for an xbox steering wheel.
1 - 3 of 3 Posts
Status
