1 - 2 of 2 Posts
Discussion Starter #1
Hi, right now I have my xbox360 connected to my computer monitor via hdmi cable. My pc is also connected to my monitor via dvi cable. I'm currently sharing my speakers between the two via a setup consisting of a f/f coupler, a y cable, and two m/m audio cables. Basically, I have one cable going to my monitor's audio out port, and one going to my computers, so my speakers can work with both.
My problem is this. The sound on my computer works perfectly fine, like it did before I shared my speakers. But my xbox360's volume doesn't seem to go very high right now. Even when I turn the speaker's dial to max it just sounds moderate. Are there any settings in my computer or xbox dashboard, or anything like that I can change to achieve a higher volume? Thanks.
Discussion Starter #2
anyone have any idea? Basically I'm wondering if there's any way to increase the xbox360s volume through the dashboard or computer or something like that.
1 - 2 of 2 Posts
