1 - 2 of 2 Posts
Hello,
Is it possible to have sony's KDL-40XBR3 TV's remote to control Motorola DVR (DCT6412)? As of now its only able to change channels and turn it on/off, but nothing else, such as pause/rec/play etc... Has anyone been able to program the sony remote with such device? Tkx.
You might have better luck trying to use the cable remote with the TV. Most likely you'll be able to access most commonly used keys on the TV with the cable remote, and if you have a UEI remote (like Comcast, some TW, some Cox), you should be able to add any other keys you need from the original remote, and you might even be able to program function like discrete input that's not even on the original remote. Which cable remote do you have? If it is the right type of remote, I might be able to tell you what you need to do to get all the functions you need on the remote.
1 - 2 of 2 Posts
