I was able to capture and replay with this setup, but the PQ is not very good. Any ideas how to improve this?
AVSForum Tech Talk Podcast with Scott Wilkinson Click here for details.
Enter to be our Home Theater of the Month Click here for details.
Originally posted by Owen rgathright, You have not given much info to go. Flyds is an excellent program and is not the problem. What input are you using on the Xcapture Composit or Svideo ? (I am using S-video) What resulution are you useing to capture? (I believe it is 640x480) What compression codec are you using and how is it setup? (I will have to check. I am not on that computer right now.) I capture 720x576 PAL to Xvid 1Pass 95% quality and quality is very close to the original. Most people could not tell the difference. (I know I am not using PAL and I will check the others items with your settings. Regards, Owen |
The PQ is a better with Dscaler than with the others. The PQ with VitualVCR and Flyds is worse since installing Zoomplayer and ffshow. |
