Xcore86 2W @ 1Ghz x586 system on a chip
2778 Views 3 Replies 2 Participants Last post by  tux99
I wasn't aware of the Xcore86 CPU-
http://www.xcore86.com/site/
Anything Not Intel or AMD is a welcome sight (minimizing monopoly power and all...)
It's being used in a netbook-
http://www.norhtec.com/products/gecko/index.html
and an open/FOSS iPad alternative-
http://www.xcore86.com/site/node/16
http://mobile.slashdot.org/article.p.../02/09/2138200
WattOS is used on the netbook- low power optimized Ubuntu
http://www.planetwatt.com/
WattOS is based on Ubuntu 9.10 (the current version), with low resource/memory optimized WM/DE (openbox/LXDE) and purportedly min-power optimized drivers/resident apps. Looks like a good alternative to Ubuntu Netbook Remix/Moblin for max battery life on netbooks/notebooks or max speed on older desktops (
1 - 4 of 4 Posts
Xcore86 Edubook netbook specs:
CPU 1GHz Xcore86 Device on Chip™
Graphics Integrated Graphics Chip
Memory 512MB / 1GB DDR2
Display 8.9" WSVGA 1024 x 600 resolution TFT LCD screen with LED backlight
HDD SD Card or IDE Flash Disk
Audio Line-out, Mic-in, Internal Mic, Internal stereo speakers
Ethernet Built in 10/100 Base-T
USB 2.0 ports External : 3 ports, Inernal : 1 port (reserved for WIFI, GPRS, CDMA, 3G or 3.5G USB dongles)
I/O D-sub 15 pin VGA out, integrated SD card reader, touch pad
Power / Battery Rechargeable AA Battery - NiMH 8 pcs (4 hours max) or
Li+3S (4 hours max) or Li+3S2P (6 hours max)
AC 100V-240V (no external adapter)
An open issue is the GPU and GPU drivers- they would need to support Flash video acceleration like VDPAU or this thing could be useless for web video.
No idea what the GPU is based on- ATI/Nvidia/VIA/SiS/Intel/?
See less See more
Webtop might make an interesting media center front end, depending on GPU capability-
http://www.xcore86.com/site/Showcase
The GPU is indeed the problem, I seriously doubt it can even drive a 1920x1080 display, but it almost certainly won't be able to play any HD video or HD flash.
Also it has no PCIe bus (only PCI) so you can't use a CrystalHD with it.
Seems like a AMD Geode competitor, not anything usable for a HTPC.
1 - 4 of 4 Posts
