OK so here's my problem.
I just got a new HDTV LG LD550, it does 1080p, and all the standard inputs.
I tried connecting my pc with an XFX 5770 video card via HDMI.
The resolution was set to 1920x1080, and i noticed the pixels were not as crisp as it should be.
I then switched to the VGA input on the tv. Using the dvi-vga connector the tv now displays 1920x1080 correctly, everything is super crisp.
How do I get my HDMI to display like this. Is it a setting in windows, or through ati's video card, or something on my tv. Im not sure exactly how to fix this.
Here are a couple of pictures i took so you can see the difference.
Thanks in advance.
Thanks in advance.
